RCU Forums - View Single Post - Pheonix Strega
Old 12-14-2004 | 02:26 PM
therotund1's Avatar
therotund1
Default RE: Pheonix Strega
The only issue this one will have versus Kaos is slowing it down. Mine flies fine slow-ish, it just takes some time to slow it down to landing speed.
The taildragger part isn't an issue if you're used to steering the plane on the ground during take off. Most taildraggers want to turn left, my Strega is no exception, due to torque. It's not super duper squirrelly on the ground but, it's not one you want to just go wide open throttle with from a standing start. Ease into the throttle and steer it 'till the tail flys and it won't be a problem. I take mine off at 1/2 throttle all the time then gag it when it's in the air.
