Hard to say, everyone does not turn the prop the same..Really slow rotation will let the compression leak past the rings and turn over easy, fast rotation just the opposite...Take a cylinder off and look at the piston, check for a ring stuck in the groove or brown on the piston below the rings...Either condition is not normal...
