RCU Forums - View Single Post - Howard Engineering - Kwik Fli III – Build
Old 12-14-2004 | 10:21 PM
8178's Avatar
8178
My Feedback: (17)
Default RE: Howard Engineering - Qwik Fli III – Build
The fuselage was damaged pretty badly, but I decided it would be easer to repair it than buy a new one. The first step was to re-glue the bottom balsa part of the fuselage back on to the fuselage with epoxy. Next I cut part of the balsa bottom away on one side to gain access to the side of the fuselage to repair the stringer that is under the balsa bottom. I made a new stringer, glued it in place and then pulled the fuselage side down and glued it in place on the stringer.
To be continued..
ID:	203040   Click image for larger version
ID:	203041   Click image for larger version
ID:	203042   Click image for larger version
