RCU Forums - View Single Post - Howard Engineering - Kwik Fli III – Build
Old 12-14-2004 | 10:49 PM
8178's Avatar
8178
My Feedback: (17)
Default RE: Howard Engineering - Qwik Fli III – Build
The next step was to cut the fiber glass patch to go inside the fuselage. I used some 80 grit on the inside of the fuselage to ruff up the area before putting the cloth in place. This fuselage is made from polyester resin (my preferred fiberglass) so I mixed up some resin and brushed in on the cloth keeping it as dry (light resin) as possible. In these images you can see the trial fitting of the cloth on the outside of the fuse but it is glassed to the inside of the fuse.
To be continued..
ID:	203060   Click image for larger version
ID:	203061   Click image for larger version
ID:	203062   Click image for larger version
