RE: Howard Engineering - Qwik Fli III – Build
View of the fuselage showing the cloth and resin on the inside. I glued the piece I cutout on the bottom back on while the wood strips were still on the fuse. After the resin setup over night I removed the wood strips from the fuse. The last image shows how the parts lined up and you can see the CA spots on the fuse.
To be continued..
