RE: Howard Engineering - Qwik Fli III – Build
The next step was to sand the outside of the fuselage along the cracks with 50 grit to make a tapered low area along the cracks about 2” wide so glass could be applied to the outside of the fuse. You do not want to sand all the way through the glass but sand enough to make space for the new glass.
To be continued..
