RCU Forums - View Single Post - Howard Engineering - Kwik Fli III – Build
Old 12-15-2004 | 12:00 AM
8178's Avatar
8178
My Feedback: (17)
Default RE: Howard Engineering - Qwik Fli III – Build
After making sure the gear length was correct I cut out the wheel well and a path way for the air lines. I like to glue in a piece of balsa to cover the slot. After the wheel well is ruff cut with the hot wire I sand the foam with sand paper glued to a spray can top to finish.
To be continued..
ID:	203119   Click image for larger version
ID:	203120   Click image for larger version
