RCU Forums - View Single Post - Howard Engineering - Kwik Fli III – Build
Old 12-15-2004 | 12:07 AM
8178's Avatar
8178
My Feedback: (17)
Default RE: Howard Engineering - Qwik Fli III – Build
I decided that I would use ailerons that are cut out of the foam wing like I had done on the original so I had to add a small balsa strip to the trailing edge of the wing. I also wanted to use the original aileron linkage that I had removed from the damaged wing. The balsa piece was glued to the foam and then shaped and sanded to continue the wing to a sharp edge.
To be continued..
ID:	203124   Click image for larger version
