RCU Forums - View Single Post - Howard Engineering - Kwik Fli III – Build
Old 12-15-2004 | 12:28 AM
8178's Avatar
8178
My Feedback: (17)
Default RE: Howard Engineering - Qwik Fli III – Build
I didn’t take any photos of the wing covering process. After the trailing edge was completed I sanded the foam lightly with my long sanding block to smooth the surface in preparation for Dave Brown’s Sorghum contact glue. I did the usual butt joining of the 1/16 wing skins, etc. After the wing skins were glued on with the Sorghum I sanded the leading edge and glued on the leading edge ¼” balsa sheet and shaped the leading edge contour into the wing sheeting. Next I sanded the trailing edge and glued on 1/8” square bass wood strip. The wing was then sanded with my long sanding block to shape the bass wood to the wing contour and a nice sharp edge. 2” wide wing tips were cut from light balsa blocks.
To be continued..
ID:	203127   Click image for larger version
ID:	203128   Click image for larger version
ID:	203129   Click image for larger version
