ORIGINAL: rc-rodeo
Spacey,
in plains some thermal uplifts will build up, increase and vanish on a random basis.
On slopes there is an uplift in correlation to the slope shape. Ipacs claims to calculate the uplift from the slope geometry, wind direction and strength.
The general strength of the uplift as well as main wind direction and turbulence factor can be set by the user as it was already in AFP.
Regards
rodeo
Thank you for the reply. I know the slope lift is very real even in the current AFP. I usually go play on the hangliding scenery and they do use the slope geometry quite well to calculate slope lift. It's great fun. I haven't had much luck soaring thermals on it though but there is a good chance that I just need more practise with it. I hope they made the planes react a little better when crossing through a thermal. I couldn't get the old one to show the lift like in real life, like a wing dropping. It does show the glider dropping the nose and picking up speed though.
