RCU Forums - View Single Post - Howard Engineering - Kwik Fli III – Build
Old 12-15-2004 | 08:27 AM
8178's Avatar
8178
My Feedback: (17)
Default RE: Howard Engineering - Qwik Fli III – Build
I use a table saw to cut the dihedral in the wings because it makes a very smooth cut on the end of the wing. The wing is setup with the equivalent of 1” under each wing tip. Because the wing is close to an equal taper this setting makes the top of the wing almost flat. I glued the wing together with epoxy and held it together with masking tape. The front of the wing must have a small notch to clear the nose wheel. After completing the notch the wing was glassed with glass cloth and epoxy.
To be continued..
ID:	203233   Click image for larger version
ID:	203234   Click image for larger version
ID:	203235   Click image for larger version
