RE: H9 Clipped Wing stand offs
Jeff,
From memory, they are just under an inch. 18mm seems to ring a bell.
Best way to figure it out is to fit the cowl, then measure the distance from the cowl ring to the firewall and then deduct the length of the engine. Add approximately 1/8" to the number you calculated for spinner clearance.
Hope this helps
Ari
