RCU Forums - View Single Post - Slow roll on LT-40
Old 08-27-2002 | 02:29 AM
Someone11-RCU
Default Slow roll on LT-40
Originally posted by Crosswind
Your roll problem could also be caused in part by adverse yaw. If your ailerons have equal throw up and down, the down aileron will have more drag than the up one which tends to pull the wing back with the up aileron wing moving forward. Looking at the plane from the top it would be a twisting motion, with the nose wanting to go left in a right turn, and vice versa. The effect is much the same as if you applied rudder in that direction, which is opposite of the way you want to roll. Coordinated rudder, in the same direction as your ailerons can overcome this and help perform a much better roll. The rudder corrects the yaw the down aileron is trying to cause. It often helps to have differential on the ailerons, with more up movement than down... sometimes twice as much is needed, depending on the wing used. I realize this may not be your problem, but I've seen it lots of times. Good luck!
I agree with crosswind. I have a Kadet LT-40 and the ailerons are slowed down considerably... I often find myself doing slow rolls with having to use a lot of down elevator to keep the roll from descending. A couple of weeks ago I decided to see what effect the rudder would have on the roll, and it payed off. Once I tried it with the rudder and aileron, and the roll is so much faster. The clevises that connect to the servo arm are all the way in. The nylon horn that the clevis snaps into is 3/16in down from the top of the torque rod. It may take a little getting use to, but using rudder and aileron together will help your rolls. I find it easier to roll to the right, because of the engine torque pulling the plane to the left.
Hope I helped!
-Brian
