ORIGINAL: bmwfxr receiver mounted 2 feet from ign. module along with throttle servo(plastic connecting rod attached to throttle). I hope somebody has suggestions on how to fix this.
Start by confirming that you are using a resistor plug together with a shielded plug lead. The resistor plug should contain an "R" in it's number.
Not only should the receiver be kept at a distance from the ignition, but also all associated receiver wiring. That means battery, switch harness, charge connector, and all servo wiring. Also check to see that all your grounds are secure.
> Jim
