The only reason I would like to see it on a video is to check if the full UP elevator causes the plane to fall forward in the tail slide. A slight tilt to the rear like 1 or 2 degrees shouldn't bother it. I don't have XTR so I can't test it. The video would tell all with the stall(what a poet)
. I don't want to see anyone take an unfair advantage of another simulator's physics engine simply by saying theirs can do it. Many video hosts will host a small video for less than $10 for a month with unlimited hits however I don't think I am allowed to mention a hosting companies name here. Maybe someone with extra space would volunteer to host it for you [sm=surprised.gif] if it indeed looks correct.
I hope I haven't opened a can of worms with this challenge[sm=confused.gif].
ORIGINAL: svemoe
I had to check it out, and it seems I can do it in XTR unless the plane doesn't get to far over against the "backside". If so, it does as you said and just slides straight down. Although I'm no 3D-pilot I just tried it as you described, and it worked. I know you would prefer a video, but I don't know how, or rather where, to upload it. Sorry.
Sverre
