RE: The right Li-po?
It would help to know which prop you are going to use as that will help determine the amp draw from the battery. I myself like the TP1320 or the TP2100 and brushless I go with 3-cells. I have motocalc to help determine the amp draw of different props for the batteries if you decide on a prop and need help.
