RE: starting & priming??
first u put fuel in the tank and then put your finger over the carb and turn the prop until you see fuel going into the carb. Then u put the glow plug on it and using a starter or chicken stick turn the prop. to get it started it usally wont go the first time. but if you use a electric starter it goes ALOT quicker
