RE: Great Planes 300s .40 (RTF)?
You are correct the tx is the 6xh used for heli flight but seller says as you did that should not be a problem in this plane. He has flown with this system in the aircraft now since new (10 to 15 flights) with no issues. It has mixing and dual rates on it which is primarily what I would need for a/c use as well as ATV settings. I definetly will take up the assistance of an instructor but the thumbs seem to still be fresh on the control sticks (use G2 regularly) so hopefully I know when to push and when to pull.
Has anyone ever had an issue with the stock tailwheel? I have heard that while tough it has little spring/zero. Any problems encountered with this? Thanks again for the feedback and pictures from all, much appreciated this is helping me with my decision making process, everything looking pretty positive so far. Thanks
Hos
