RE: Muffler for .40LA
Not starting anything with jim:-) But just a heads up... I removed my
muffler baffle on my LA 46 and it did increase the power somewhat
but I did end up with a few dead sticks due to no fuel pressure at the
tank due to the removal of the baffle and if not you could cause
more problems due to lean running of the engine during certain
maneuvers.. So baffle went back in after increasing the hole some
what... I also drilled/cleaned out the the tail pipe exit along with
adding a few more drilled holes around the tail pipe base.. But
really with this engine the power improvement was pretty much non-
exsistent..
