RCU Forums - View Single Post - gas engine interference
Old 12-17-2004 | 04:24 PM
Redrata
Default RE: gas engine interference
ORIGINAL: ptgarcia
The hole !QUOT!you have to keep everthing at least 12!QUOT! from everything else!QUOT! ideology just isn't true. Like dirtybird said, what you need to do is find the source of the radio noise and fix it. I have my ignition switch and ignition battery about 4!QUOT! from each other in my Laser with Brison 3.2 and have no interference issues. I highly recommend the Bosch shielded cap as tkg suggests. It does a great job suppressing electrical noise. Good luck!
hi ptgarcia, I am also quite new in gas. Is it also necessary to make some place between the ignition switch and the ignition battery? Or it was a mistake, what you really wanted to say was between the RX switch and Ign battery?
