JW,
Thanks for the tip on the prop. What do you think about a 12.5 X4 APC?? I think I have a couple of those laying around here somewhere. It will probably be after the holiday obligations are over before I can get started. I did alot of research you know comparing the YS 63 vs the Saito 72, 82 and 100. I decided to give the YS a go and see what happens. Most complaints I have heard are from higher altitude folks. At 15' above sea level (did anyone say storm surge), that shouldn't be a problem here. I would like to get the UCD 46 done first as I am trying to save the 110FZ for another UCD 60 that will hopefully be done over this winter. If not, I'll stick her in Miss A instead of the Saito. Now that we live in the Bastille with our 155MPH rated metal roofing system and our 140MPH rated accordion window shutters, I should't be getting my planes busted up by flying debris
