Original Strykaas: ... Application is speed
Hi Strykaas,
your motto is "Faster !!!!!!!", isn't it?
So if you are in need of "
TRUE speed" instead of what could be called "sport speed" associated to Shrikes, Patriots, DD and Whips you may consider to build a "true extreme" speed plane in combination with the FIRE engine configuration. Mr.
combatpigg currently builds such a true speed plane designed for maximum speeds above 230 mph depending on the engine/pipe setup.
His thread: HEY! LET'S BUILD A SPEED PLANE!!! can be found here:
http://www.rcuniverse.com/forum/HEY%...2303195/tm.htm
These "zero drag" planes are in fact quite simple constructions and easy to fly - they behave very neutrally. A confirmation to the superior aerodynamics incorporated here [8D]
Any more suggestion ?
You also might want to join the coming
German Speed Cup to be held in 2006 (maybe already in 05). The more participants from abroad (also overseas) the better
http://www.rcuniverse.com/forum/Pics...2257303/tm.htm
