PCM is FM, so is most PPM. You will find all the major manufacturers higher end systems are FM whether they are PCM or PPM. There are still a few AM PPM systems available and, many years ago you could also get PCM using AM. To better give you an explanation of the various systems, check out
www.torreypinesgulls.org/Radios.htm
