RCU Forums - View Single Post - Disappointment with Vectorflight
Old 12-18-2004 | 11:57 AM
ckangaroo70's Avatar
ckangaroo70
My Feedback: (51)
Default RE: Disappointment with Vectorflight
You won't have much trouble Brad. The instructions don't give all the details, but the Plane goes together very easy regardless. Just take your Time when installing the wing joiners, and make sure you get a good clean fit before using any epoxy. Once you get your wing done, and to where it will mount to the Plane nice, the rest is just pretty simple. The only thing I would suggest for a mandatory add-on is to make sure you install upper and lower struts to the stab. All the Hardware is good stuff, and the Covering is wrinkleless and gorgeous. The cowl is also fantastic, but the wheel pants are a little on the thin side, so you may also decide to go with a stouter set of aftermarket Pants or just leave them off all together. Very few things to find fault with in these Planes. They are just a super well designed, quallity aircraft priced way under what you would expect an Airplane of this caliber to be priced at.
