RE: Best Adhesive for Polyester Glass!
Bob, Im using Hysol 9460 on my Polyester F-16, works great!! I am using the aplicator Gun ($19.99 from McMaster-Carr) to create nice fillets around the bulkheads, but you could easily do the same with your fingers.
Install the bulkhead, then use a small flat head screwdriver to cantilever between the bulkhead and the fuselage and use your finger to tuck in part of the fillet glue between the fuse and the former.
Good luck.
david
