RE: prop flying off
Most of the info posted here seems reasonable, but I would not use channel locks to tighten the prop nut. Any kind of pliers will eventually chew up the nut, a wrench is designed to install and remove nuts. Get a real box end or open end wrench and tighten the prop really well. I use a flare nut wrench where possible.
