Hey Dion what computer are you using. Ive been messing around with the Hypercam an capturing anything over about 5 fps slows the computer so much you cant hardly fly. Every time it snaps a frame it shuts the sim off which makes things very jerky.
I was going to set AFP to 256 colour to try to speed things up but for some reason you cant do it with that prog. 16 bit is as low as I can go.
By setting the playback fps up you can get decent video but the speed is so fast it doesnt look realistic.
Im running a AMD 3000 512memory with a Geforce 5200 video card.
Im not sure this is good software to use unless someone can figure out a better way to get it to work.
