RE: Motor problems
If you have the car on and switch the tx off, the car may do just about anything on it's own. If the motor runs when it glitches, it's probably not a problem with the motor. Have you reset trims on the tx to neutral? There may be a throttle trim turned down. You may also try resetting the esc.
