RCU Forums - View Single Post - Best Adhesive for Polyester Glass!
Old 12-19-2004 | 08:05 PM
Bob_B's Avatar
Bob_B
Default RE: Best Adhesive for Polyester Glass!
I went to Mc Master-Carr's websire and looked for Hysol. I found the Gun, Mixer tips and adhesive but I did not see alisting for 9460 or any other similar number.
Here is what I found? Can someone point me to the right code? Thanks, Bob
Begins Reaches
Loctite to Full Temperature Mix
No. Harden Strength Color Range Ratio Each
E-00CL Epoxy 5min. 6hrs. Clear -65° to +200° F 1:1 6430A16 $8.51
E-00NS Epoxy 5min. 24hrs. Translucent -65° to +300° F 1:1 6430A17 8.51
E-90FL Epoxy 90min. 6hrs. Gray -65° to +300° F 1:1 6430A18 8.51
E-20HP Epoxy 20min. 20hrs. Off-White -65° to +350° F 2:1 6430A19 8.51
E-30CL Epoxy 30min. 24hrs. Ultra Clear -65° to +200° F 2:1 6430A23 8.51
E-120HP Epoxy 120min. 24hrs. Amber -65° to +350° F 2:1 6430A24 8.51
U-05FL Urethane 5min. 24hrs. Off-White -65° to +300° F 1:2 6430A21 8.90
Adhesive Gun 74695A71 Each $20.00
Mixer Nozzles (Full pkg. is 12) 74695A12 Each PartialPkg. $1.00 FullPkg. $0.75
Other Loctite Hysol Adhesives
Loctite
No. Color Each
E-05CL Epoxy Clear 6430A25 $8.98
E-40FL Epoxy Gray 6430A26 8.51
E-60NC Epoxy Black 6430A27 7.63
E-60HP Epoxy Off-White 6430A28 8.51
E-20NS Epoxy Tan 6430A29 8.51
U-10FL Urethane Clear 6430A31 10.58
