RCU Forums - View Single Post - prop flying off
Old 12-20-2004 | 10:21 AM
jnesbitt82
Default RE: prop flying off
When I went to start it today I didn't have any problems with the prop coming off but it just would not start with a chicken stick so I had to use the electric starter. After doing about three qwick burst from the starter, I removed the glow plug, turned the engine over, and didn't have any fuel come out. I then started to rotate the prop by hand looking at the piston. After about the third rev, the prop started hanging up. I kept turning it but every few revs the prop would still hang up. Is this where it is still new? The motor only has about 7 flights on it. Another thing, the fuel I started to use said not to use after run oil. Should I heed to this advice?
I have used after run oil up till now.
