RCU Forums - View Single Post - SIG Kadet Senior ARF question
Old 08-28-2002 | 01:43 AM
Ed
Default SIG Kadet Senior ARF question
You don't have a problem. The Pic shows the fuselage pointing downward, making the downthrust appear to be excessive. Look at the top of the Fuse, and the lateral balsa seam under the white and red Monocote. It's not level. That seam is in essence your thrust line, (roughly,) and you need that much downthrust if you are using a .46.
You'll be OK; go fly the thing !
