RCU Forums - View Single Post - Composite ARF Impact
Old 12-20-2004 | 05:29 PM
  #285
Erik Johansson
Default RE: Impact
ORIGINAL: pbrantuas
Eric,
It's interesting that the Jeti people would say that an Advance 77-3p Opto controller is a no go for a 10s pack, and that 24 cells is the maximum when they advertise on the label that the controller is intended for 12-30 cells.
I have about 22 flights on mine with the NeuMotor setup on a 10s3p pack and so far so good. I have the timing set on "hard" and on the ground I'm pulling 55 amps. After a 10 minute flight the motor temp is about 105 degrees F, and the controller is about 120 degrees F.
Regards,
Pedro
Hi,
You may want to ask them yourself. But they renamed it 75-3p Opto pretty early on and out 8-24 cells on the label. I guess there must have been some reason for them to do this. Though I don´t know what that would be. But if it´s running fine then by all means run it. I just thought you should know.
/Erik
