RE: JR X-378 flaperons
Danny,
The switch I am using to move the flaperons as flaps is the Flap rocker switch (also referred to as Aux 1) which is associated with channel 6.
The only mix I am using is the built-in mix which automatically came into effect when I selected "Flaperon" in the "Wing Type Selection" in System Mode. (This mix presumably slaves channel 6 to channel 2 to achieve the Aileron function, and slaves Channel 2 to 6 to achieve the Flap function.)
The arrangement is actually working very well, with the Aileron Stick moving the Flaperons as Ailerons, and the Flap rocker switch moving the Flaperons as flaps. The only problem, as I said previously, is that I can't stop the channel 2 flaperon moving upwards above its neutral position when the Flap rocker switch is inadvertently operated upwards above neutral.
Danny, if what I'm asking is just impossible to achieve don't worry. I'll just be more careful and make sure I don't move the Flap rocker switch above the flaperon neutral position during flight.
Many Thanks
Ed
