RE: JR X-378 flaperons
You can inhibit the flap rocker completely by going to the LEVER function and pressing clear until it says OFF 0%. Or you can set up a program mix, flap to flap, and set the rate with the rocker moved up to -100% leaving the switch ON so no switch will affect the mix.
