RCU Forums - View Single Post - Kit Building..
Old 12-21-2004 | 10:39 AM
randy41
Default RE: Kit Building..
Just a few.
1) Read instructions first.
2) prep your self with the needed equipmnt/supplies as per instructions.
3) Must have a flat service to build on.
4) Build 1 section at a time untill you get some experience behind you.
5) Most things that are glued togeather are repairable. Even if you make
those darn glue mistakes( Object is to not to make them, read instructions).
6) If your not sure what to do about a procedure than ask someone or
post a message in this fourm.
There will be more people pick up were i left off probably.
Like i mentioned this is just a few things to consider.
You can get your fancy signature by editing your profile.
