H9 SU-31 Test Flight
rcavi8ter and tp777fo, I am putting hitec digital 5625's in the wings and i was going to used the stock 1" al. servo arms that came with them but they seem to short and don't line up with the hard block in the ailerons. They hit right at the edge. What servo arms are you using and what is the length. I don't think it would be wise to install the control horn at the edge of the blocking. I also don't think it is a good idea to angle the push rods so they line up with the center of the blocking in the aileron. I need help, I am having trouble finding longer al. arms for the hitec servo. Also what about the elevators it calls for 1" arms. Are the al. hitec okay for here or should i find a longer arm like 1.25" any ideas where to look?
