RE: PERFORMANCE ADVANTAGE GWS DRAGONFLY DIRECT DRIVE/VS/GEAR DRIVE?
didn't mean to confuse, GWS has 2 versions of the the dragonfly out now, one uses the a electric motor on the tail running a reduction gear and it also has a smaller -150? size -main motor. the 2nd version also uses an electric motor for the tail rotor but the rotor is driven straight off the motor shaft, no reduction gear, and it also has a slightly larger main motor-a 300 i beleive. I was wondering which would be the better one to own if given a choice between the two. I have time on the glow helies and am aware of the various advantages/disadvantages, of belt vs bevel gear vs wire vs torque tube, but the electric stuff is new too me.
thanks
zonk
