ORIGINAL: pcol2480
I now have it so when it is connected and I switch it on it is fine, but once I start turning left and right it starts buzzing agagian, it cant seem to get back to centre once I have turned to either side.
i have similar servos. my buz when you turn left right, thats just the way these servos are.
any pressure on these servos will make them buzz. to prove this dont connect the servo to linkages and turn the servo left/right - there will be no buzz, but once you apply a little back-pressure with your finger then it will buzz.
mine go back to center, and the buzz stops. i not sure why your one not. did you use the servo horn that was provided? if your servo horn is loose then it wont center.
i had my on for 3 gallons on my wrx and
vb servos and no problems.
