RCU Forums - View Single Post - PCM or PPM that is the question!
Old 08-27-2002 | 09:43 PM
Jim_McIntyre
Default PCM or PPM that is the question!
This is an often, and hotly debated topic and associated with many myths.
Some simple facts
- HOLD is not fail-safe
- all PPM units will be twitching uncontrollably long before the interference level will cause a pcm unit to stop listening
I won't debate that you can fly aircraft without problems on ppm... the difference is what happens when a problem occurs.
When I lose that tenuous radio link, I want the power delivered to my blades to drop to minmum and the flightpath to be as predictable as possible, not surging around erratically . It's about safety , not saving a replaceable (although relatively expensive) piece of equipment.
PCM delivers on this requirement, PPM does not. It's a pretty simple choice to me.
