Originally posted by jkelly0321
This is killin' me. C'mon guys, how can there be a market for "ppm" if it doesn't work? Pulse Position Modulation (PPM) is a form of frequency modulation (FM) as is Pulse Code Modulation (PCM). And I'm pretty sure Multiplex did not invent PCM.
Your pretty sure based on what, you abviously lack information.
It might be best to just reply with your actual experience so one can make an educated decision.
The truth is either method is fine depending on your application and preference.
PPM is just fine as some have indicated. I have experienced glitching from various sources and have always been able to resolve it. The cause of a few of my glitching experiences are:
1.)small crack in aluminum boom support (vibrating metal)
2.)anodizing worn off on pinion radiating RF on tail drive wire
3.)defective gyro (interference in rx from gyro control wire)
4.)loose screw on aluminum boom support (vibrating metal)
Most of the glitches I have ever had were a quick momentary glitch that did not prohibit landing the helicopter.
Some glitching has lead me to suspect damage (notched bearings) in the main shaft bearings, starter shaft bearings and engine bearings but have never been proven since I would just replace notchy bearings as they were discovered.
Hope this helps,
GOODDAY!
