ORIGINAL: ROGER RUSSELL
What Speed controller is everybody using if used with the stock motor that comes with it?
Heard only needed a 10 amp one??
It doesn't have a motor included with it. It is setup for a radial mount type outrunner brushless motor. The Castle P 10 will probably be the most popular ESC to use because of it's light weight. I'm curious to see how much the E-flite 20 amp control weighs. The site says 1/2 oz. which isn't bad for a 20 amp control, but that still about twice what the P 10 weighs. I wonder how much lighter it would be if the pins were removed from it and the motor wires soldered directly to the esc.
