RCU Forums - View Single Post - Blades and Blade Tracking
Old 08-28-2002 | 08:04 PM
Fissy
Default Blades and Blade Tracking
bigwave,
Aaaah ! Great pix ! Obviously not a problem. I will definitely order a pair if the replacements are also warped. Thanks.
HSH,
Checked the spindle and sure enough, it is slightly bent. Actually took several rolls on different surfaces to tell but it looks bent by the slightest of margins. Must this be replaced b4 flying again ? Doesn't seem like that slight of a tweak would effect things much but I don't know. What'ya think ? Also, I don't really want to take out the whole main shaft. When I fly, the head button appears like it's not even moving from turning by hand to hovering and every speed in between. Is this enough to verify that main shaft is OK ? Is there any other way to sufficiently check it w/o full removal ?
Thanks.
