RCU Forums - View Single Post - Help w/ Door hinges
Old 12-24-2004 | 06:31 PM
LuvBipes's Avatar
LuvBipes
Default RE: Help w/ Door hinges
khodges, thanks for the explanation, but if I understand you correctly, then I am to insert the hinge in the door frame in the middle of the fuse side between the 1/8" balsa and 1/8" ply lamination, right? Now, if I then attach the hinge to the door on the inside (the door is 1/8" plywood, won't it still bind??
