ORIGINAL: ramcfarland
Continues to look fantastic.It is Top Gun material,time again of essence do you have any thought's/offer --->FRANK TIANO where are you<-- to bring it to 'Top Gun 05, providing you get it in the air;if you have not already. If the flying proves reiable you could up set the cart so as to speak at Top Gun I do believe- I have one real concern: what is the running time on your engines,are they reliable??have you "run" them with your beautiful cowls installed;taken any cylinder head temerature readings so far, with the cowls INSTALLED;do you have a back up that you could:break in your twin ZDZ40's,check reliability and "dial in" the to gas burners prior to installing them in your Gem. One more..It will be in Toledo (yes--)
