I almost forgot don't put on the rotostarted until after tank 15. Because of the high compression of the engine you will be popping oneway bearings!! Use the pullstart , loosen the plug 1/8 of a turn before you start pulling it when it starts tighten it back up!! AND get a pair of work gloves to protect your hand from blisters while you are usings the pullstart. Dont forget to check the o-rings on the carb! Good luck! I hope you have as much fun with yours as I have with mine!! Peace. OOPS almost forgot before attempting to start up your zilla.46 warm it up first with a hair dryer for about 3 min it will make starting it up that much easier!!
