Problems with 3PK / ESC combo
Dear sirs I am using a 3PK radio with an FP-R113iP receiver. I have ran it in gas trucks for a year with no problems. I just purchased a Mamba 25 Performance set-up from you for the Losi Mini-T. Trouble is, I cannot get the throttle to work through the esc. Steering works just fine but I get no respose whatsoever from the throttle/brake. All values are centered and I turned off the fail safe in case it was causing the problem. Is this receiver not capable of handling an esc unit? I know everthing else works as I am using the car/esc unit with another radio. Your help would be appreciated.
Paul Eagon
