RE: Post pictures of your RACERS!
Its amazing how much easier it is to fix something like this than it looks. I sanded up the left side to smooth things out. Added some thin CA on the inside and out, and sanded down smooth. The left side is ready for a little clear and it will be done.
The right side needed a little more attention. The force of the impact cracked the servo tray loose. I have never seen Pro-Set crack like this, so I had to re epoxy a few loose places tight. Since I was missing so much wood, I cut a piece of 3/16 to size and epoxied everything in place with a few clamps. The actuall spinner nut damage is just going to get filled with lightweight filler.
Here are a few repair picks, not much time at all.
