RCU Forums - View Single Post - Lanier Edge540t ??!help
Old 01-15-2003 | 07:15 AM
  #39
bgi
My Feedback: (7)
Default Lanier Edge540t ??!help
T28, I need some advice on my Edge. I have:
HS225MG's in the tail for elevator
Saito 180 in front
645MG pull-pull in std servo tray for rudder
Other radio components up front as far as possible
I need to add significant weight up front to balance on the Lanier-recommended CG. I forget how much - something like 6 oz.
Do you think I should:
1) Add nose-weight?
2) Remove the 225's and put a pull-pull on the elevator?
3) Extend the nose so I can mount the engine further forward?
I guess there is an advantage to adding weight. I can remove it to move the CG back once I'm ready for that.
