Lanier Edge540t ??!help
You can drill new holes for the horns or install a pull-pull like I'm probably going to do.
If you put in a pull-pull, it's better to have the horn holes aft a bit instead of fore. Forward horn holes in a pull-pull are bad news because the tension increases with deflection.
