AFP Deluxe HERE
Santa brought mine. Had one minor hiccup on channel assignments. Once figured out, I was "flying" in 10 minutes. Roland Matt, I'm not, but the Smaragd that is in the sim is quite good. Minor tweaks will make it really awesome.
If you're trying to practice serious sequence stuff, the default field is pretty good for that, and you just have to turn on the "Trace". You'll see QUITE rapidly if your lines are straight, and if rolls are centered.
This is an awesome sim, and far better than G2, FMS, or the others I've tried. Can't compare it to Reflex; don't need to. I am a HAPPY camper with this guy just as it is.
So far, and I've only played for an hour or so.... the airplanes handle VERY realistically, and the interaction with the environment is just flat amazing. Thank you to EVERYONE who made this one happen. I may finally figure out that P-05 yet !!!!
